Trigger
API Triggers can be used to execute external scripts and applications.
When an API Trigger executes, it sends a web request to a specified url. The web request includes query parameters which the receiving server can use to interact with the session from which the call originated.
Request
The following query parameters are relevant:
Type | Key | Meaning | Notes |
Querystring / GET parameter | token | API token for session access | |
Querystring / GET parameter | f | Expected return format. | Defaults to "JSON" |
Request header | Referer | The originating Tygron server's url | "Referer" is misspelled in the original http specification. |
Response
The web server is expected to send a response which is a parseable JSON object. If the trigger type is TQL, each key of the object must be a valid TQL update statement, and each value must be a value in decimal notation.
Examples
Some simple examples exist to demonstrate the call-and-response functionality required for API triggers.
TQL example: Geometry counter
The following example is PHP code which reads out a number of Item types, and writes the results into Globals.
//The API token is retrieved from the query parameters, the server address from the referer header. $apitoken = $_GET['token']; $serverurl = isset($_SERVER['HTTP_REFERER']) ? $_SERVER['HTTP_REFERER'] : $_GET['server']; //The script will obtain 3 types of geometries, from 3 urls. $urls= [ 'buildings' => $serverurl . 'api/session/items/buildings?f=JSON&token=' . $apitoken, 'neighborhoods' => $serverurl . 'api/session/items/neighborhoods?f=JSON&token=' . $apitoken, 'areas' => $serverurl . 'api/session/items/areas?f=JSON&token=' . $apitoken, ]; $queries = []; //For each of the prepared urls... foreach( $urls as $key => $url ) { //...set up a webcall to the url... $ch = curl_init(); curl_setopt($ch, CURLOPT_URL, $url); curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1); $webcallResult = curl_exec($ch); curl_close($ch); //...interpret the received data as JSON, turning it into an associative array... $features = json_decode($webcallResult, true); //...count the number of entries in the array... $amountOfFeatures = count($features); //...compose the name for the global to write the result to... $globalName = strtoupper($key).'_COUNTED'; //...and use that to create the TQL update statement. $queries[ 'UPDATE_GLOBAL_VALUE_WHERE_NAME_IS_' . $globalName ] = $amountOfFeatures . '.0' ;//The Tygron Platform expects results with a decial notation. } //Output the created map as a json string. echo json_encode( $queries, JSON_PRETTY_PRINT ) exit();
The script will produce an output with the following structure:
{ "UPDATE_GLOBAL_VALUE_WHERE_NAME_IS_BUILDINGS_COUNTED" : "11559.0", "UPDATE_GLOBAL_VALUE_WHERE_NAME_IS_NEIGHBORHOODS_COUNTED" : "11.0", "UPDATE_GLOBAL_VALUE_WHERE_NAME_IS_AREAS_COUNTED" : "1.0" }
