Geo Plugin
Revision as of 10:40, 16 December 2021 by Rudolf@tygron.nl (talk | contribs)
This article is a stub.
A Geo Plugin is a definition for a connection which should be established when a new Project is created. One or more Geo Plugins can be defined in a Project Template. When that Template is used to create a new Project, the connections defined in the Geo Plugins are established, and data within the new Project's extent is imported. Depending on the Geo Plugin's configuration, various types of data can be added to the new Project automatically.
Types
Geo Plugin type Feature type Effect Configurations
AREA Vector Geolink:
  • Matching Attributes
  • Mapped Attributes
BUILDING Vector Function
Geolink:
  • Function
  • Mapped Attributes
ROAD Vector Function
Geolink:
  • Function
  • Mapped Attributes
TERRAIN_HEIGHT Grid The elevation model is updated with data from all sources. Data from earlier sources take precedence over later sources. Source(s)
WATER_BOTTOM Grid The elevation model is updated with data from all sources, but only in location with a Water Terrain. Data from earlier sources take precedence over later sources. Source(s)
Geolink
A Geolink is a subdefinition for a geoplugin. It provides a specific filter and operation to perform on data found in the source of the Geo Plugin. A geolink provides the following linkage options:
Item definition
The data matching the Geolink's filter will be imported as Items with the selected definition. For example, when the Geo Plugin is for Buildings, features matched by the Geolink are added to the Project with that specified Function.
