Shoreline (Water Overlay)
Revision as of 09:03, 10 February 2022 by Rudolf@tygron.nl (talk | contribs)
When a Waterway polygon is not correctly positioned in relation to the DEM this can result in filling up the nearby land with water at the start of the simulation. This will result in a lower water level then is expected from the water area value. To correct this, a "shoreline" is added at neighbouring cells. At the start of the simulation, these shoreline cells will also be filled with water up to the nearby water level to prevent the initial flush.
  • This option is active by default.
