How to import AutoCAD DXF files
Revision as of 08:14, 29 August 2022 by Rudolf@tygron.nl (talk | contribs) (Created page with "{{stub}} DWG files can be indirectly imported into a Project, by first converting them to a DFX file (the open-standard equivalent). DXF files can then be importe...")
This article is a stub.
DWG files can be indirectly imported into a Project, by first converting them to a DFX file (the open-standard equivalent). DXF files can then be imported directly through the Geo Data Wizard, as either features in the Current Situation, or in the Future Design.
How to import a DWG/DXF as a future plan:
  1. If the filetype is currently DWG, use an AutoDesk application to open it and save/export it as DXF.
  2. Open the Geo Data Wizard, which will assist with importing data.
  3. When importing for the Current Situation, opt to import Constructions.
    When importing for the Future Design, opt to import Measures.
  4. Select the DXF file, either as a local file on your computer or on the Geo Share.
  5. etc
