How to add or remove a Scenario
Adding a Scenario
A scenario can be added in two ways in the Tygron Platform; through a ribbon drop down option or by selecting the Add button on the bottom of the left panel, after selecting scenarios in the ribbon bar.
How to add scenario to a project:
- Select Multi-Scenario → Scenarios
- Select Add new Scenario from the drop down menu
- Or select Add on the bottom of the scenario panel
Removing a Scenario from a project
Sometimes an earlier implemented scenario becomes redundant, or an error has occurred that renders a scenario useless. In such cases it is possible to remove the scenario completely.
How to remove scenario in a project:
- Select the scenario to be removed on the left panel
- Select Remove on the bottom of the left panel
