How to add or remove a Scenario
Editor → Multi Scenario (Ribbon tab) → Scenario (Ribbon bar)
Adding a Scenario
A scenario can be added in two ways in the Tygron Platform; through a ribbon drop down option or by selecting the Add button on the bottom of the left panel, after selecting scenarios in the ribbon bar.
How to add scenario to a project:
  1. Select Multi-Scenario → Scenarios
  2. Select Add new Scenario from the drop down menu
  3. Or select Add on the bottom of the scenario panel
Removing a Scenario from a project
Sometimes an earlier implemented scenario becomes redundant, or an error has occurred that renders a scenario useless. In such cases it is possible to remove the scenario completely.
How to remove scenario in a project:
  2. Select the scenario to be removed on the left panel
  3. Select Remove on the bottom of the left panel
