Weir formula (Water Overlay)
Revision as of 09:51, 27 October 2022 by Frank@tygron.nl (talk | contribs)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
Optionally, when a Weir drop threshold is configured, the weir height can update depending on the water level and weir drop time:
Failed to parse (unknown function "\if"): {\displaystyle z_{w,t} = z_b \if max( w_l, w_r) > w_{dt} \or t_{wd} > 0 }
otherwise
if
otherwise
For free flow, capacity is calculated directly:
For submerged flow, the following calculation is used:
Where:
  • = The height of the water column relative to the top of the weir, on the side with the highest water level.
  • = The height of the water column relative to the top of the weir, on the side with the lowest water level.
  • = The water level on the left side of the weir, relative to datum.
  • = The water level on the right side of the weir, relative to datum.
  • = The height of the weir at time t, depending on drop mechanism.
  • = The WEIR_HEIGHT of the weir.
  • = The water bottom elevation at the weir.
  • = The weir drop timeout.
  • = Dutch weir factor, set to 1.7.
  • = The WEIR_COEFFICIENT of the weir.
  • = The WEIR_WIDTH of the weir.
  • = The potential rate of water flow across the weir.
  • = The ratio of water heights on either side of the culvert.
  • = The potential rate of water flow across the weir, based on a free flow calculation.
  • = The potential rate of water flow across the weir, based on a submerged calculation.
  • = Loss coefficient for submerged weirs, set to 0.9.
  • = Flow area, based on the highest water column height relative to the top of the weir, and WEIR_WIDTH of the weir.
  • = Acceleration factor of gravity, set to 9.80665.
  • = The water flow which takes place.
  • = Computational timestep.
  • = Cell size.
Related
Structures
Weir
Models
Surface model
