Min max elevation (Water Overlay)
MIN_MAX_ELEVATION
boolean
Whether to use highest and lowest elevations found for a grid cell for land and water respectively when interpreting the elevation model.
True
In situations where the calculation grid size is larger than the elevation model's accuracy, the values for the elevation model are averaged per grid cell to compute a matching elevation model. This setting computes multiple averages to be computed, and the highest value to be used if the grid cell is land, and the lowest value to be used if the grid cell is water. This allows smaller waterways to be preserved better when the interpreted elevation model for the Water Overlay's calculations is less accurate.
