Weir formula (Water Overlay)
Revision as of 15:37, 15 December 2022 by Frank@tygron.nl (talk | contribs)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
hs=max(0,max(wl,wr)zw,t)
hd=max(0,min(wl,wr)zw,t)
Optionally, when a Weir drop threshold is configured, the weir height zw,t at time t can update depending on the water level and the remaining weir drop time:
zw,t={zb,if twd,t>0zw,otherwise
twd,t={twd,if max(wl,wr)>wdt and twd,t<=0twd,t1Δt,otherwise
rh=hdhs
Q={min(Qs,Qf),if rh>0.5Qf,otherwise
For free flow, it is calculated directly:
Qf=fwcwb(hshd)3/2
For submerged flow, the following calculation is used:
Qs=UlossA2g(hshd)
Δw=ΔtQΔx
Where:
  • wl,t = The water level on the left side of the weir, relative to datum, at time t.
  • wr,t = The water level on the right side of the weir, relative to datum, at time t.
  • zw,t = The WEIR_HEIGHT of the weir, at time t.
  • hs = The height of the water column relative to the top of the weir, on the side with the highest water level, at time t.
  • hd = The height of the water column relative to the top of the weir, on the side with the lowest water level, at time t.
  • fw = Dutch weir factor, set to 1.7.
  • Cw = The WEIR_COEFFICIENT of the weir.
  • Cd = Corresponding Coefficient of discharge. Part of the Dutch weir factor.
  • b = The breadth of weir crest, adjustable using the WEIR_WIDTH.
  • Q = The potential rate of water flow across the weir.
  • rh = The ratio of water heights on either side of the culvert.
  • Qfree = The potential rate of water flow across the weir, based on a free flow calculation.
  • Qsubmerged = The potential rate of water flow across the weir, based on a submerged calculation.
  • Uloss = Loss coefficient for submerged weirs, set to 0.9.
  • A = Flow area, based on the highest water column height relative to the top of the weir, and WEIR_WIDTH of the weir.
  • g = acceleration due to gravity.
  • Δx = Cell size.
Free flow coefficients
To clarify the free flow formula in comparison with other definitions: When h0.01 meters, the following holds.
fwcwCdg
Cd=0,633(10.0003h)32
For h generally larger than that, the flow can be calculated up to 5.5% smaller than expected when using the second pair of coefficients. However, this can be corrected with the weir coefficient if necessary.
  • Cw = The WEIR_COEFFICIENT of the weir, set to a default of 1.1
  • Cd = Calculated Coefficient of discharge.
  • h = Weir head; the height of the water column relative to the top of the weir.
Related
Structures
Weir
Models
Surface model
{{Article end | references= Cite error: <ref> tag with name "ref-ISO" defined in <references> is not used in prior text.
