Traffic Plugin
Revision as of 10:32, 19 January 2023 by Frank@tygron.nl (talk | contribs)
The Traffic Plugin is an optional geo plugin that is part of the project generation task-flow for new projects situated in the Netherlands. It provides the road system with traffic intensities.
The Roads tab of advanced (geo) options show when selection an area for a new project.
This Traffic Plugin is active when one or more of these source is active as a Geo Option :
In general, the Road's geoplugin for generated projects situated in the Netherlands, use the BGT or Top10NL to place road geometries. The NWB source is used to add the NWB ID to these roads, such that it can be used for matching traffic intensities.
The NWB id, listed as wvk_id, of a road near the city of Utrecht .
INWEVA
The Inweva excel showing multiple NWB-ids with corresponding hourly work day traffic intensities.
The INWEVA Excel[1] is provided by an infrastructure department of the Dutch government. It contains year average hourly traffic intensities for work and weekdays per traffic group: Cars, Vans and Trucks. In the Tygron Platform the workday traffic intensities are matched to roads. Information from the INWEVA Excel can be matched to roads using the NWB id.
NSL
The NSL shown in their viewer. It contains traffic intensity information of the most important road sections per jurisdiction.
The NWB can provide year-average hourly traffic intensities for work or week days. However, it only contains information on the most prominent roads. Information from the NSL can be matched to roads from the BGT and Top10NL, using the NWB id. When a match is found, the daily traffic intensities are converted to an hourly value in the following way:
where,
is the daily traffic intensity for traffic type t.
is the estimated average hourly traffic intensity for traffic type t.
The NSL road section data is obtained from Centraal Instrument Monitoring Luchtkwaliteit and hosted on the Tygron Geoserver. The current data variant that is hosted on our geoserver is cimlk 2022 wegverkeer jaar 2021.
Infomil
An infrastructure department of the Dutch government provides an Excel file, vi_lucht_geluid_v4.xls[2][3], that contains macro's to estimate traffic intensities for the road properties provided. The following properties are requested:
  • The traffic speed based on the type of road. The type of road is determined by other geo plugins, generally selecting the road type based on road names, nwb data and bgt properties of the road (closed, semi closed, gravel or open).
  • Single traffic direction or both ways.
  • Amount of lanes on the road.
  • Adjacent parking and bicycle lanes.
  • Degree of urbanization, determined based on zip code or based on CBS Neighborhoods. Only two situations are considered: 5 or < 5.
This leads to the following categorization:
codename description (Dutch)
IR_BIBO_50_2x2 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, 2 bij 2 of meer rijbanen.
IR_BIBO_50_1x1_NP 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, minder dan 2 bij 2 rijbanen, geen parkeerplekken.
IR_BIBO_50_1x1_WP_AF 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, minder dan 2 bij 2 rijbanen, parkeerplekken, apart fietspad.
IR_BIBO_50_1x1_WP_GAF 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, minder dan 2 bij 2 rijbanen, parkeerplekken, geen apart fietspad.
IR_BIBO_30 1 richtingsverkeer, binnen bebouwdekom, 30 km/u.
IR_BUBO_80_2x2 1 richtingsverkeer, buiten bebouwdekom, 80 km/u, 2 bij 2 of meer rijbanen.
IR_BUBO_80_1x1_AF 1 richtingsverkeer, buiten bebouwdekom, 80 km/u, minder dan 2 bij 2 rijbanen, apart fietspad.
IR_BUBO_80_1x1_GAF 1 richtingsverkeer, buiten bebouwdekom, 80 km/u, minder dan 2 bij 2 rijbanen, geen apart fietspad.
GIR_BIBO_50_2x2 geen 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, 2 bij 2 of meer rijbanen.
GIR_BIBO_50_1x1_NP geen 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, minder dan 2 bij 2 rijbanen, geen parkeerplekken.
GIR_BIBO_50_1x1_WP_AF geen 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, minder dan 2 bij 2 rijbanen, parkeerplekken, apart fietspad.
GIR_BIBO_50_1x1_WP_GAF geen 1 richtingsverkeer, binnen bebouwdekom, 50 km/u, minder dan 2 bij 2 rijbanen, parkeerplekken, geen apart fietspad.
GIR_BIBO_30 geen 1 richtingsverkeer, binnen bebouwdekom, 30 km/u.
GIR_BUBO_80_2x2 geen 1 richtingsverkeer, buiten bebouwdekom, 80 km/u, 2 bij 2 of meer rijbanen.
GIR_BUBO_80_1x1_AF geen 1 richtingsverkeer, buiten bebouwdekom, 80 km/u, minder dan 2 bij 2 rijbanen, apart fietspad.
GIR_BUBO_80_1x1_GAF geen 1 richtingsverkeer, buiten bebouwdekom, 80 km/u, minder dan 2 bij 2 rijbanen, geen apart fietspad.
Each category returns daily traffic values per traffic type. These values are converted to hourly values by multiplying them with 1/24 and then stored in the corresponding function values for the road: Cars, Vans and Trucks;
Additional Road Attributes
The following attributes are added for roads updated with information from the NSL source, but are not used for matching or determining functions. These attributes are only stored as data for the roads.
attribute description
HEAVY_TRAFFIC_SPEED   Maximum speed for heavy traffic.
 LEFT_SHIELD_HEIGHT  Height of the (tunneling) shield on the left side of the road.
 LEFT_TO_RIM_DISTANCE Distance from the left side of the road to the rim of a vehicle.
 LEFT_TO_SHIELD_DISTANCE Distance from the left side of the road to the (tunneling) shield.
 NUM_LIGHT_VEHICLES_DYN A dynamic amount of the light vehicles.
 RIGHT_SHIELD_HEIGHT Height of the (tunneling) shield on the right side of the road.
RIGHT_TO_RIM_DISTANCE Distance from the right side of the road to the rim of a vehicle.
 RIGHT_TO_SHIELD_DISTANCE Distance from the right side of the road to the (tunneling) shield.
 HEIGHT Height value of the road.
  1. https://downloads.rijkswaterstaatdata.nl/inweva/INWEVA_2020.zip
  2. Infomil estimates information ∙ Infomil ∙ Found at: https://www.infomil.nl/onderwerpen/lucht-water/luchtkwaliteit/slag/hulpmiddelen/inschatten/ ∙ (last visited: 26-9-2022)
  3. Infomil VI Lucht en Geluid v4 ∙ Infomil ∙ Found at: https://www.infomil.nl/publish/pages/107533/vi-lucht_geluid_v4.xls ∙ (last visited: 26-9-2022)
