| Icon |
Attribute |
Unit |
Range |
Description |
Default value |
LIMIT_AREA |
nominal value |
Whether and how calculations in the simulation should be limited to specific locations of the project area. |
Entire map |
| 0. |
Entire map: Calculations are performed across the entire map. Water can flow anywhere.
| 1. |
Limit to Water Areas: Calculations are only performed in the locations where water areas are present.
| 2. |
Limit to specific Areas: Calculations are only performed in the locations where limitation areas are present.
- The overlay attribute name for this option is LIMIT_AREA, which is similar to the default Overlay key for Limitation areas.
- When any limit is in effect, water can flow between valid locations, even if those locations are defined through different relevant features (e.g. 2 adjacent water areas).
- In step 1 of the Water Overlay Wizard, the to be calculated area can be selected. When chosen for the option Limit to specified areas, an extra step in the wizard is added.
