Attribute action panel
Revision as of 10:13, 8 February 2023 by Frank@tygron.nl (talk | contribs) (Created page with "The ''Attribute action panel'' is a panel that is shown when a Stakeholder selects an Attribute Action from the Action menu panel. This panel can be used to draw a selection , which will be used to select buildings to which attributes from this Attribute Action will be set. Optionally, whether the Attribute Action is configured with a '''Fixed Value''' or not, the Stakeholder can adjust the attributes in the Attribute Action. <gallery heights=500px w...")
The Attribute action panel is a panel that is shown when a Stakeholder selects an Attribute Action from the Action menu panel. This panel can be used to draw a selection , which will be used to select buildings to which attributes from this Attribute Action will be set. Optionally, whether the Attribute Action is configured with a Fixed Value or not, the Stakeholder can adjust the attributes in the Attribute Action.
Template:User interface nav
