Attribute action panel
The Attribute action panel is a panel that is shown when a Stakeholder selects an Attribute Action from the Action menu panel. This panel can be used to draw a selection , which will be used to select buildings to which attributes from this Attribute Action will be set. Optionally, whether the Attribute Action is configured with a Fixed Value or not, the Stakeholder can adjust the attributes in the Attribute Action.
A Stakeholder draws a selection for the Solar panel Attribute Action.
Since the Attribute Action does not have fixed values, the Stakeholder can provide alternative values for the SOLAR_PANELS attribute.
The Stakeholder has performed the Attribute Action and the building has now it's SOLAR_PANELS attribute set.
