TQL
Please note: This page is currently being updated! |
TQL
The Tygron Query Language is a special-purpose programming language designed for obtaining spacial area information from a specific game session on the Tygron Engine. The primary reason for its development was to make an easy to use bridge between the Tygron Engine and Microsoft Excel.
Queries
The operation used in TQL is the query, which is performed with the declarative SELECT statement. SELECT retrieves data from a running Tygron game session. The SELECT statements have no persistent effects on the game session itself.
Queries allow the user to describe desired data, leaving the Tygron Engine responsible for planning, optimizing, and performing the physical operations necessary to produce that result as it chooses.
A query includes a parameter to include in the final result, immediately following the SELECT keyword. Currently, one of the following result parameters can be chosen:
| Result Parameter | Description | Example |
FLOORSIZE
Floor size of buildings. | SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES
LOTSIZE
Lot size of buildings. | SELECT_LOTSIZE_WHERE_CATEGORY_IS_OFFICES
UNITS
Amount of housing units. | SELECT_UNITS_WHERE_CATEGORY_IS_SOCIAL
DIKES
Surface space of constructed dikes or levees. | SELECT_DIKES_WHERE_ZONE_IS_1
Comparison Predicate and Clauses
The SELECT and result parameter are followed by the WHERE statement. The WHERE statements includes a comparison predicate, which restricts the information taken into account by the query. The WHERE clause eliminates all information from the result set where the comparison predicate does not evaluate to True.
The comparison predicate consists of 0 or more clauses. Clauses consists of three parts;
- Clause Type
- Operator
- Value
The clause types and expected values currently supported are:
| Clause Type | Description | Value Type | Example |
CATEGORY
A building belongs to the specific Function category | Function category | Function category
FUNCTION
A buildings belongs to a specific Function | Function ID | SELECT_FLOORSIZE_WHERE_FUNCTION_IS_621
DIKE
A building is constructed or planned on top of a particular type of Dike (or Levee) | Function category | Function category
MAP
A building is present in the specified map or view. Also see Simulation Type | Function category | Function category
STAKEHOLDER
A building belongs to a specific Stakeholder | Stakeholder ID | SELECT_DIKES_WHERE_STAKEHOLDER_IS_3
MAP
A buildings belongs to the specified Function category | Function category | Function category
MAP
MAP
Operators
TQL clausses currently support the following Operators:
| Operator | Description | Example |
IS
Equal to | CATEGORY_IS_OFFICES
Simulation Type
Depending on the simuation type, the map parameter is named as followed
| Simulation Type | Description | CURRENT
MAQUETTE
| Planning | Equal to | CATEGORY_IS_OFFICES
| Timeline | TODAY | MODEL |
