How to export a DXF
DXF Files can be exported from the Tygron Platform directly to be used as a base in an AutoCAD Drawing. The video below explains how this works.
How to export a DXF for use in AutoCAD:
- Make sure that a Geo Plugin is present in your project. To learn more about Geo Plugins check out [Plugin|this] page
- Open the Geo Data Wizard, which will assist with importing data.
- When importing for the Current Situation, opt to import Buildings.
When importing for the Future Design, opt to import Measures. - Select the DXF file, either as a local file on your computer or on the Geo Share.
- Select the layers in the DXF file to import.
- Follow the remaining steps in the Geo Data Wizard to select and import the features as desired.
- Finish the Geo Data Wizard to finalize the data import process.
