How to add a Disclaimer to a Template Project
When offering up a Template Project to other Users in the same Domain, or when preparing to offer one to the broader Tygron Community, adding in information about the purpose, intent, options, liabilities and warnings of using it may be useful or even mandatory. For this purpose, the Tygron Platform allows for configuring a Project Disclaimer. This is a message which will be displayed to a user when creating a new Project based on the template, and which will need to be explicitly accepted before the Template is actually accessed.
How to add a Disclaimer to a Template Project:
- Ensure the Template Project to which the Project Disclaimer is to be added is writable.
- Open the Template Project in the editor.
- Go to Tools → Template.
- Find the Disclaimer input field and enter the Disclaimer text.
- The Project Disclaimer is displayed during the creation of a new Project, when a Template Project with a Project Disclaimer is selected for use.
- The Project Disclaimer is only displayed when creating a new Project via the Tygron Client. Using a Template Project with a Project Disclaimer programmatically via the API will not explicitly present the Project Disclaimer.
- The Project Disclaimer is not carried over to the new Project. If a Template Project A is used to create a Template Project B, which is then itself also turned into a Template Project, using Template Project B to create a new Project will not display a Project Disclaimer, unless one is explcitly set for B as well.
- The Project Disclaimer is not part of the Project Data, but of the Project Metadata. This means that when changing the Project Disclaimer in the Editor it is changed immediately and does not rely on saving the Project. Changing the Project Disclaimer and then closing the Editor without saving will still result in a changed Project Disclaimer.
