How to import a DWG file in ArcGIS Pro
Revision as of 06:21, 5 October 2023 by Rudolf@tygron.nl (talk | contribs)
A DWG (Drawing) is used in CAD software and can be exported from most 3D animation packages.
How to import a DWG file into ArcGIS Pro:
  1. In ArcGIS Pro go to the "Map" tab and select "Add Data"
  2. Choose the DWG file. If the file is not visible in the add Data panel, click on the refresh button (top right corner)
  3. Select the Multipatch layer, right click on the Multipatches layer and choose properties.
  4. Select the Elevation tab and select On the ground and then Ok to place the model on the surface terrain.
  • An AutoCAD 2004 or AutoCAD release 14 export works best to create an SLPK file
<<Back to SLPK manual
