Basic Mode
The Basic Mode is a option for project creation which allows calculation and analysis of very large project areas. The Basic Mode can be used in regional planning, such as for Urban expansion planning, flood risk management, transportation and energy and sustainability planning.
Characteristics
The characteristics for a Basic Mode Project are:
  • A Project must be created as a Basic Mode Project when created. It is not possible to change whether a Project is or isn't a Basic Mode Project later on.
  • A Basic Mode Project will still be counted as license usage, but only for 1/25 the usual size. A Basic Mode Project of 50km² will count for 2km².
  • The maximum size of a Basic Mode depends on both the License and the hardware used. If you can normally create 30x30 km projects, you can create a 180x180km project in Basic Mode.
Optimizations
To facilitate working with very large areas, the Basic Mode encompasses a number of optimizations spanning various aspects of both Projects and the software:
  • The minimum calculation grid size is set to 5x5m, although larger Grid Cells are still possible.
  • The elevation model is automatically set to a resolution of 10m.
  • The data sets used for building a basic mode project are: Esri, AHN4, BRO, CBS, Top10NL, NWB, BAG and BRP. See project sources for more information on theses sources. Custom 3D models (such as 3D BAG and I3S) while not be available during Project generation.
  • Buildings smaller than 10m² are automatically culled from the Project data whenever the Project is saved.
