How to create a Basic Mode Project
For some Projects, especially at more broad regional levels, the Basic Mode may provide more appropriate performance while still being well-suited for a broad range of use-cases and calculations. However, the choice for the creation of a Basic Mode Project must be made at the time of Project creation.
Main menu → New Project
How to create a Basic Mode Project:
- In the main menu, opt to create a new Project.
- Enter the name for the Project as usual.
- Select a laguage and unit system as usual.
- For the Detail level, select Basic.
- Click on "Create new Project", and progress through the rest of the Project creation process as usual.
1. Log in to client.
2. Select new project in the Main Menu.
3. After naming your project, select Basic for Detail Level.
4. Use the Map Wizard to select the Basic Mode map size and location of your project.
- Creating a Basic Mode Project requires a Strategic Partnership.
- When using a Project Template to create a new Project with, the new Project will inherit its Detail level from the Project Template. A Template Project which is not a Basic Mode Project will result in a new Project which is not a Basic Mode Project. A Template Project which is a Basic Mode Project will always result in a new Project which itself is also a Basic Mode Project.
