Ground infiltration formula (Water Overlay)
Revision as of 12:45, 25 January 2024 by Frank@tygron.nl (talk | contribs)
du=HsurfaceWLunderground
r=Wunsat/du
di=min(du,ΔtIund)
Finally, calculate the actual amount of water infiltrating.
Δw=dir
Where:
  • du = The height of the unsaturated zone.
  • r = Ratio of water to height in the unsaturated zone.
  • di = The height distance in the unsaturated zone which can be subject to infiltration to the saturated zone.
Related
Groundwater level formula
Surface infiltration formula
Underground seepage formula
Models
Underground model
Infiltration model
Tracer flow model
