Ground infiltration formula (Water Overlay)
Revision as of 12:49, 25 January 2024 by Frank@tygron.nl (talk | contribs)
du=Bcwg
r=Δwu/du
di=min(du,ΔtIg)
Finally, calculate the actual amount of water infiltrating.
Δwi=dir
Where:
wg = The groundwater level, relative to datum.
Bc = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
du = The height of the unsaturated zone.
Δwu = The amount of water in the unsaturated zone. The height of the water column if the equivalent amount of water was placed on the surface.
r = Ratio of water to height in the unsaturated zone.
Δt = Computational timestep.
Ig = The GROUND_INFILTRATION_MD of the underground terrain type.
di = The height distance in the unsaturated zone which can be subject to infiltration to the saturated zone.
Δwi = The underground infiltration which takes place.
Related
Groundwater level formula
Surface infiltration formula
Underground seepage formula
Models
Underground model
Infiltration model
Tracer flow model
