Ground infiltration formula (Water Overlay)
Finally, calculate the actual amount of water infiltrating.
Where:
- = The groundwater level, relative to datum.
- = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
- = The height of the unsaturated zone.
- = The amount of water in the unsaturated zone. The height of the water column if the equivalent amount of water was placed on the surface.
- = Ratio of water to height in the unsaturated zone.
- = Computational timestep.
- = The GROUND_INFILTRATION_MD of the underground terrain type.
- = The height distance in the unsaturated zone which can be subject to infiltration to the saturated zone.
- = The infiltration which takes place from the unsaturated zone to the saturated zone.
Related
- Formulas
- Groundwater level formula
- Surface infiltration formula
- Underground seepage formula
- Models
- Underground model
- Infiltration model
- Tracer flow model
