Groundwater level formula (Water Overlay)
Revision as of 13:00, 25 January 2024 by Frank@tygron.nl (talk | contribs)
hs=Vsfs
wg=hs+Bcdb,c
Where:
hs = The height (column) of the saturated zone.
Vs = The amount of water in the saturated zone. The height of the water column if the equivalent amount of water was placed on the surface.
fs = The WATER_STORAGE_PERCENTAGE of the underground terrain type, used here as a fraction.
wg = The groundwater level, relative to datum. Also known as the watertable.
Bc = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
db,c = The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
