Ground evaporation formula (Water Overlay)
Ground evaporation is calculated per cell.
For all ground evaporation calculation, the ground water depth at time t is used.
Feddes oxygen stress factor:
Feddes saturated zone root update factor:
Max potential evaporation:
Evaporation unsaturated:
Potential evaporation saturated:
Evaporation saturated zone:
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
where
- = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
- = the ground water level (datum height) at time t.
- = the depth of the ground water level, which is equal to the column height of the unsaturated zone at time t.
- = the transpiration factor of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
- = the evaporation rate of the weather at time t
- = the calculated feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
- = the calculated feddes saturated zone root update factor, calculated using the 1st and 2nd root depths and the feddes trapezium interpolation model and the ground water depth.
- = The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
- = the column height of the saturated zone covered by the roots
- = the nth root depth value.
- = the amount of water in the unsaturated zone.
- = the potential max evaporation
- = the evaporation in the unsaturated zone
- = the potential evaporation in the saturated zone
- = The WATER_STORAGE_PERCENTAGE of the ground terrain type, used here as a fraction.
- = the evaporation in the saturated zone
- = the total evaporation from the ground.
Related
- Formulas
- Groundwater level formula (Water Overlay)
- Models
- Ground model (Water Overlay)
- Evaporation model (Water Overlay)
