Ground bottom flow formula (Water Overlay)
Revision as of 15:47, 26 January 2024 by Frank@tygron.nl (talk | contribs)
Hoe is kwel geïmplementeerd in het Tygron Geodesign Platform? (Dutch only)
Ground bottom flow from outside the project area is calculated per grid cell. The formula is based on the principles used in the formula of Pankow for estimating seepage[1].
The water level change due to seepage is calculated using the following formula:
The external bottom head pressure is variable over time by the introduction of :
Finally, the actual amount of water floowing into the ground from the deeper ground layers through the bottom boundary is calculated as followed:
= The water level change due to seepage, in meters.
= Computational timestep in seconds.
= Ground water head in the grid cell.
= Additional ground water level (or head) of the external zone causing the seepage at time t, in meters
= Ground water level (or head) of the external zone in meters at timeframe .
= Additional variation of bottom head pressure over time
= Resistance of the separating layer in days at timeframe
= Water storage fraction of the soil
= Seeped in water in m
  • The calculated is essentially the change in groundwater level, inherently taking into account the porosity of the soil. The final is representative of the actual amount of water, i.e. the height of the water, if the relevant quantity of water wasn't in the underground but sat on the surface instead.
  • and can both be provided as spatially variable values using prequel overlays. These prequels can have multiple timeframes, as indicated by the formula, allowing changing head and resistances over time.
  • can be provided as a set of values, variable over time.
  • A seepage head lower than the water level in the project is also allowed, resulting in water seeping out to a region outside the project area.
Related
Groundwater level formula (Water Overlay)
Models
Underground model (Water Overlay)
