Max infiltration m (Water Overlay)
Revision as of 16:33, 26 January 2024 by Frank@tygron.nl (talk | contribs)
Icon | Attribute | Unit | Range | Description | Default value |
MAX_INFILTRATION_M | m | Assumed maximum amount of infiltrated water that can be stored in the ground layer. | 1 |
- Contrary to the title of the model attribute, it is actually a storage amount. The distance is misleading, since it does not interact with the local storage capacity of the ground layer.
- This option is only relevant when the ground water mode is set to Infiltration only. In case the ground water mode is set to Complete, this model attribute is ignored.
