Avg terrain storage m (Water Overlay)
Revision as of 13:01, 29 January 2024 by Frank@tygron.nl (talk | contribs)
Icon | Attribute | Unit | Range | Description | Default value |
AVG_TERRAIN_STORAGE_M | m | 0 to 10000 | When determining the water level of a land cell that will be averaged, the level will ignore the part that is reserved for storage. | 0,05 |
This storage amount will allow water to infiltrate into the surface and evaporate, before being averaged away into the water way.
- This option is only used when the surface water mode is set to Avg Terrain. In the later two cases, the situations in which this occurs is very limited, only for Sewer and drainage cells, since land type cells are not assigned for these modes.
