Ground watertable result type (Water Overlay)
Revision as of 15:07, 29 January 2024 by Frank@tygron.nl (talk | contribs)
Icon | Result type | Unit | Mode | Description |
GROUND WATERTABLE | m + datum | Last | The groundwater level, relative to datum. |
The default behavior of this result type is to display only the groundwater level. If the GROUND_WATERTABLE_WITH_SURFACE setting is used, the output for any location where the groundwater level is close to the surface is the surface water level instead.
- This result type requires the Ground water mode to be set to COMPLETE.
- If the GROUND_WATERTABLE_WITH_SURFACE setting is used, and the groundwater level fluctuates close to the surface, the groundwater level may appear to jump erratically. When this occurs and the this impacts the output in an unacceptable way, it is recommended to disable that setting, and separately consider results for the SURFACE_LAST_DATUM for the above-ground waterlevels.
