Water stress result type (Water Overlay)
WATER_STRESS | m (mm)¹ | Maximum | The amount of water on the surface, similar to SURFACE_MAX_VALUE. Ignores water on water terrains unless it exceeds ALLOWED_WATER_INCREASE_M. |
Any water on the surface is considered water stress. Open water is usually designed to function as a buffer for water, meaning an increase in the amount of water is not necessarily considered stress, unless the water level increases too much. "Too much" is defined by the ALLOWED_WATER_INCREASE_M attribute. As long as that amount of water is not exceeded, water stress in that location is considered 0.
