Ground evaporation formula (Water Overlay)
Revision as of 10:10, 27 February 2024 by Frank@tygron.nl (talk | contribs)
Ground evaporation is calculated per cell.
For all ground evaporation calculation, the ground water depth at time t is used.
Feddes oxygen stress factor:
Feddes saturated zone root update factor:
Seasonal transpiration factor:
Max potential evaporation:
Evaporation unsaturated:
Potential evaporation saturated:
Evaporation saturated zone:
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
where
= the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
= the ground water level (datum height) at time t.
= the depth of the ground water level, which is equal to the column height of the unsaturated zone at time t.
= the transpiration factor at current season c, of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
= the transpiration factor at coming season n, of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
= Season fraction. Used for interpolating the transpiration factor.
= Can be supplied as four values; it is an interpolated value based on the current and next season.
= the evaporation rate of the weather at time t
= the calculated feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
= the calculated feddes saturated zone root update factor, calculated using the 1st and 2nd root depths and the feddes trapezium interpolation model and the ground water depth.
= The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
= the column height of the saturated zone covered by the roots
= the nth root depth value.
= the amount of water in the unsaturated zone.
= the potential max evaporation
= the evaporation in the unsaturated zone
= the potential evaporation in the saturated zone
= The WATER_STORAGE_PERCENTAGE of the ground terrain type, used here as a fraction.
= the evaporation in the saturated zone
= the total evaporation from the ground.
Related
Groundwater level formula (Water Overlay)
Models
Ground model (Water Overlay)
Evaporation model (Water Overlay)
