Evapotranspiration model (Water Overlay)
Water can evaporate from the hydrological model over time. Multiple forms of evaporation are implemented; surface and ground evaporation.
Both forms of evaporation can be configured directly by setting the weather's evaporation rate. The weather's evaporation rate is defined as a period during which a certain rate of evaporation will take place, similar to rainfall. Multiple periods of evaporation can be defined.
The evaporation is interpreted as an evaporation amount per second. In case less water is present at set location, the maximum possible evaporation will not be higher than that amount. The remainder will not be carried over to the next time step. Excess evaporation potential from a previous timestep is therefore always discarded.
The default setup for evaporation consists of a single period of evaporation. It is possible to configure an evaporation rate which varies over time. More periods with varying amounts of evaporation (including an evaporation rate of zero) can be defined.
Surface evaporation
Ground evaporation
Water can evaporate from the ground if the cell's surface meets either of the following criteria:
- A building on the surface
- The building has a non-zero WATER_EVAPORATION_FACTOR.
- The building has a non-zero root depths.
- No building on the surface
- The surface terrain type has a non-zero WATER_EVAPORATION_FACTOR.
- The surface terrain type has a non-zero root depths.
In other words: if a building is present the building's properties are used, otherwise the terrain's properties are used.
Conceptually, water can evaporate from the ground via crops and tree foliage. These can draw water from the unsaturated and saturated zones in the ground, if their roots reach deep enough and the terrain or building have a positive evaporation factor. Water is drawn from the ground and evaporated into the air, effectively removing it from the hydrological model. Water for evaporation can only be drawn from sections of the ground which are within reach of the roots, as defined by the root depth. Using the multiple root depth values, it is also possible to define a threshold at which the roots are unable, or less able, to extract ground water, due to oxygen stress. It such case up to 4 root depth values have to be provided, from deepest to less deep.
The ground evaporation can be configured directly by changing the terrain type's WATER_EVAPORATION_FACTOR and building 's WATER_EVAPORATION_FACTOR. If these attributes are set to 0, no ground evaporation will take place.
Similar to the surface evaporation, the rate of ground evaporation is also determined by the weather definition's evaporation rate. Multiplying the weather's evaporation rate and the evaporation factor of the building or terrain (as applicable) gives the actual evaporation rate for the ground.
Ground evaporation first draws water from the unsaturated region and then from the saturated region. If, according to the calculated evaporation rate, a sufficient amount of water can evaporate from the unsaturated zone, no water will evaporate from the saturated zone. Otherwise, all water in the unsaturated zone which is in reach of the roots of the building or terrain (as applicable) is evaporated, and the remainder of the amount of water which should evaporate according to the evaporation rate is evaporated from the saturated zone. The sum of evaporation in the unsaturated zone and the saturated zone will never exceed the calculated evaporation rate.
Example for dynamic evaporation
| Time key (minutes) | Evaporation rate (mm/d) |
| 35 | 1,5 |
| 42 | 1,9 |
| 120 | 0,5 |
- The first period is starts at t=0 minutes and ends at t=35 minutes. In this first period, water will evaporate at a rate of 1,5 mm per day. Uniformly this gives 1,5 / (24 * 60 * 60) = 0.000017 mm per second.
- The second period starts at t=35 minutes and ends at t=42 minutes. In this period, water will evaporate at a rate of 19 mm per day. Uniformly this is 1,9 / (24 * 60 * 60) = 0.000022 mm per second.
- The last period starts at t=42 minutes and ends at t=120 minutes. In this period, water will evaporate at a rate of 5 mm per day. Uniformly this is 0,5 / (24 * 60 * 60) = 0,000006 mm per second.
- The configuration wizard is the easiest way to adjust evaporation and rainfall.
- If the weather's evaporation rate is set to 0, no evaporation will take place in any form.
- A period without evaporation can be simulated by setting the evaporation rate for a period to zero.
- An evaporation rate of zero is allowed, but a negative evaporation rate is not. Negative evaporation rate is treated as zero.
- Ground evaporation will only take place when the ground model is active.
- The evaporation table is stored as the attribute array with the name EVAPORATION_M. This attribute is part of the weather definition associated with the Water Overlay.
- The underlying attribute array defines time in seconds.
- The next time key should always be larger than the previous time key.
- If the next time key for the evaporation rate is smaller than the previous time key for rainfall, the previous rate of evaporation is continued until the end of the simulation.
