Evaporation m (Water Overlay)
| Attribute | Unit | Description |
| EVAPORATION_M | end-time, m | An array of values, each pair indicating until what time that period of evaporation will last and what amount evaporates in that period. |
- A maximum of 10.000 values (5.000 pairs) can be defined.
- Internally each period with amount values are converted to an evaporation rate per second at a particular time in the simulation.
- The default value is set to 0.125 mm in 2 hours (0.000125 m in 7200 seconds), which corresponds to 1.5 mm per day. This value is derived from the theory described in 2.3 Gewasverdamping[1] in the book Grondwaterzakboekje, which combines the formula of Makkink with a temperature dependent factor[2] (which is approximately linear between 0 and 24 C). Based on the graph[3] with plotted lines of reference evaporation for certain months and cloudiness. The evaporation rate was selected as an average of march, june and september, for a cloudy rainy day, which corresponds to a heavy rainfall event.
- Water evaporation factor (Water Overlay)
- Evaporation formula (Water Overlay)
- Evaporation model (Water Overlay)
- ↑ 2.3 Gewasverdamping, Referentiegewasverdamping, Bram Bot (2016) ∙ Grondwaterzakboekje, Gwz2016 ∙ Impressed druk en print
- ↑ Tabel 2.3 Benadering van en , Bram Bot (2016) ∙ Grondwaterzakboekje, Gwz2016 ∙ Impressed druk en print
- ↑ Fig. 2.7 referentiegewasverdamping, Bram Bot (2016) ∙ Grondwaterzakboekje, Gwz2016 ∙ Impressed druk en print
