Simulation Core
Each Project in the Tygron Engine has its own Simulation Core responsible for executing updating the excel, triggers and grid overlays. Below an overview of each step executed:
An update is initiated by a User, an API call, or when the state changes, such as the addition of a new building, while "auto update" is enabled. Note that the initial project creation must be finished first.
Steps
1 Simulation models for Overlays are created and most attributes are initialized. For example the Water model initialized if groundwater is active or not.
2 First API Triggers (with timing BEFORE) are executed. 3 Then all TQL queries (with timing BEFORE) containing an UPDATE from Indicators and Panels. 4 After these initial update to e.g. building attributes etc the rasterization starts. All polygon data (buildings, terrains, areas, etc) is converted into grid data. This process is shared by all active Overlays for faster execution and is also the reason why all active Overlays must have the same cell size. 5 The Simulation models now contains the required grid data and may do some additional validation on them. For example are there no elevation values above 10.000 meters. 6 The Simulation model schedules jobs that are executed either on an GPU Cluster or regular CPU. The jobs are scheduled in such a way that prequel Overlays will be executed before the receiving Overlay. 7 When all jobs have finished the Simulation model compresses the resulting data into a compact format which is stored in the Overlay. 8 Then all TQL queries (with timing AFTER) containing an UPDATE from Indicators and Panels. 9 The Indicators, Panels and Globals are updated. 10 The API Triggers (with timing AFTER) are executed. 11 Finally execution times are stored and the update envelope is reset. => When the project contains multiple iterations the process is restarted at step 2 and loops untill all iteration have been completed.
