How to export AI Training Data
Revision as of 14:14, 29 January 2025 by Frank@tygron.nl (talk | contribs)
This how-to explains how to generate an AI Training Data using the Tygron Platform. This data can be used to train your own AI model.
How to export AI Training Data:
  1. Open a project in editor mode using the Tygron Client Application
  2. Optionally add a Satellite Overlay. This overlay will be used to export train images for the dataset.
  3. Determine what [item] type will be used to export a dataset for. For example areas drawn on top of the satellite overlay.
  4. Select the Export Geo Data option in the Ribbon bar popup of the selected item type. For example: Hover over Areas and select Export Geo Data
  5. Under Format, select the option AI Training Data
  6. Optionally filter the selected items using the general filter and the attribute filter options
  7. For the Overlay, select the preferred Overlay, for example the Satellite Overlay.
  8. The image size can increased, as long as the amount of expected features within the image does not exceed the maximum amount of 250.
  9. The stride can be kept at 50%
  10. Click on the Export Files button
  11. Select a suitable folder for the generated dataset.
  12. Wait until the dataset is fully generated.
