Iteration active (Grid Overlay)
Revision as of 14:30, 10 October 2025 by Maxim@tygron.com (talk | contribs) (Created page with "{{Overlay attributes|<onlyinclude> {{Overlay attributes|type=row|overlay=Average |attribute=ITERATION_ACTIVE |unit=number |range=-1 to 1000 |description=Determines in which iteration the overlay will be calculated |defaultvalue=-1 (all iterations) |icon=iteration_acvtive.png }}</onlyinclude>}} When the Grid Overlay has a <code>ITERATION_ACTIVE</code> attribute, only the iteration numbers set in this attribute will be executed. For example <code>ITERATION_ACTIVE: 0 5...")
When the Grid Overlay has a ITERATION_ACTIVE attribute, only the iteration numbers set in this attribute will be executed. For example ITERATION_ACTIVE: 0 5 will only calculate in iteration 0 and 5.
