Scenario
What are Levels?
- A Level is a relative position or rank on a scale.
How do Levels relate to the Tygron Engine
- to provide the session participants a learning curve, to get used to interacting with the Tygron Engine
- Create a first level as tutorial where a stakeholder can only perform a limited number of actions and measures. This can happen in a secluded area of the 3D World, to get acquainted with the interaction with the Tygron Engine, without affecting the outcome of the session as a whole.
- to gradually make the project interaction more complex, to match the issue in real life more closely
- Add more complex actions, measures and indicators to let session participants gradually experience the complexity of the spatial planning issue(s) at hand.
- to jump in time to a future scenario
- Each level can start with an event or measure that reflects future scenarios, such as floodings that only occur once every fifty and every one hundred years, or the sea level rising over time.
- to provide pause moments during a session
- Sessions often take place during business hours, taking up a whole morning, afternoon or even the whole day. By implementing levels the session flow can be interrupted to incorporate pause moments for reflection and refreshments.
Adding, duplicating and removing Levels in a project
Adding a Level
- Select Storyline → Levels
- Select Add new Level from the drop down menu
- Or select Add on the bottom of the left panel
Duplicating a Level
- Select the level to be duplicated on the left panel
- Select Duplicate on the bottom of the left panel
Removing a Level from a project
- Select the level to be removed on the left panel
- Select Remove on the bottom of the left panel
Changing the properties of a Level
Level
Name
In the Name field a more suitable name can be entered, if desired. Examples of this are: "Tutorial", "Prologue", etc.
Description
The description field allows for describing the level in the Editor. This is convenient when the level has added complexity. The description will also appear on the Level panel of the Admin Interface, providing a short summary of the levels in the project.
Event Bundles
- Main article: Events
By selecting the Even Bundles option of a level, it is possible to add events to a level; send automatically a message to a stakeholder, make more action menus available, etc. These events will be triggered as soon as the new level starts.
Server Events fired when chosen
On the right panel it is possible to assign the actual events to be triggered by the level. Add the event with the 'Add Event' button on the bottom of the right panel, and assign the desired event from the bottom panel with the 'Commit' button. This selection can also be cancelled.
Measures
- Main article: Measures
Besides events it is also possible to assign predefined measures to the start of a new level. For example; in the first level the stakeholders looked into different spatial alignments of possible solutions, in the second level, one alignment is constructed at the start of the level as automated measure, to accommodate further discussions. Prerequisite for this is to have the measure(s) available, then select the Measures entry on the left panel. The available measures will then show up on the right panel, which can then be assigned to the selected level.
