How to import an ONNX file using drag and drop
How to import an ONNX file by drag and drop:
  1. Create or open a project as an editor using the Tygron Client
  2. Open the folder that contains the ONNX file that you want to import
  3. Drag and drop the ONNX file onto the Tygron Client application. A popup will appear
  4. In the popup, select one of the two options:
By following these steps, a Neural Network will be created with the uploaded contents of this ONNX file.
  • Neural networks that are not referenced by an AI Inference Overlay may be removed from your project when a project is saved.
