How to use the GEOMETRY COLOR attribute
It is possible to change Geometry color (Building Attribute).
As the operation is performed by TQL, the task can be done in the Editor, with the Query Tool. More advanced users can also perform these queries through the API.
We will use the following example:
UPDATE_BUILDINGGEOMETRY_COLORWHEREATTRIBUTEISFOO
How to update the Geometry Color of a building:
- Select a building and add the attribute FOO:1.
- From the top bar, open the Query Tool (Current Situation > Queries > TQL Query Tool).
- Construct the above mentioned example, select the update color (Update to Value), and execute the query.
- The selected building color is now updated, according to the newly added GEOMETRY_COLOR attribute.
1. Select a building and add the attribute FOO:1.
2. From the top bar, open the Query Tool (Current Situation > Queries > TQL Query Tool).
3. Construct the above mentioned example, select the update color (Update to Value), and execute the query.
4. The selected building color is now updated, according to the newly added GEOMETRY_COLOR attribute.
