Template:Water Overlay height warning
The parameter is (much) higher than the average land height
The water level is much higher than the average height of the terrain, which likely means an improper value has been imported as water level. The effect in the model is undefined.
To resolve: Ensure that the configured water level is not set to a placeholder value. Note that if the water level is indeed correct but the warning persists, the warning can be ignored.
The parameter is (much) lower than the average land height
The water level is much lower than the average height of the terrain, which likely means an improper value has been imported as water level. The effect in the model is undefined.
To resolve: Ensure that the configured water level is not set to a placeholder value. Note that if the water level is indeed correct but the warning persists, the warning can be ignored. Parameters:
  • attribute: The attribute causing the issue
  • article-postfix: A postfix for the article name of the attribute
  • name: The name of the parameter (human-readable version of the attribute)
  • effect-high: The effect of having this attribute configured too high
  • effect-low: The effect of having this attribute too low
