Version 2025.8.0
Version 2025.8.0 is released on preview.tygron.com on September 5th 2025.
Geo Data
- Added support for the smartBUILD Industry Foundation Classes (IFC) format.
- Added support for the OGC GeoPackage format.
- DXF and IFC can now also be re-positioned when they miss GEO-coordinates.
Scenario
- Starting a new Scenario no longer recalculates base map, saving time.
- Added option to only calculate the Scenario where the measures are applied as limit map.
- Active Scenario attributes and description remain persistent when stopping the testrun (for comparisons).
- Added simple panel example that calculates all Scenarios Indicator scores for comparison.
- Added new TQL Selection to query the active Scenario and Overlay showing limit map.
SimCore
- Improved rasterization that matches original building polygons better (might cause small differences).
- Significant speedup for TQL Queries and rasterization.
- Added TQL query SELECT indicator score to combine indicators.
- Updates to e.g. area attributes can now also be used in indicator calculations.
- Added TQL X-Query support for Text Panels.
- SimCore Overview panel now shows performance per step as explained on WIKI.
Other
- Water: Fix proper naming for Plant Transpiration and Surface Evaporation.
- Water: Improved calibration panel and added root depth.
- Added new Floors option in Heightmap Overlay.
- Deprecated: Indicator history and Vacancy Overlay.
- Several optimizations and bugfixes for limit map calculations.
- Updated underlying polygon calculations.
- Added links to new Dashboard and AI Suite SDKs.
- Several smaller bug fixes, security updates and WIKI Updates.
