Sewer area (Water Overlay)
Revision as of 13:42, 19 June 2019 by Rudolf@tygron.nl (talk | contribs)
Similar to water level areas, sewer areas only define a sewer storage amount in grid cells that are marked as sewered. A grid cell is marked as sewered, if:
- It is covered by a construction with a SEWERED attribute > 0.
- It is covered by a sewer area with a SEWER_STORAGE attribute > 0.
A sewer area can also pump stored sewer water to an external area outside the project. However, water that has been pumped out will remain in the external area and cannot be pumped back. By default sewers do not pump water to external areas. Template:Overlay attribute
- With the Configuration wizard, sewers can be generated based on neighborhoods in the project.
- Water pumped out of a sewer cannot be pumped back once it has left the hydrological model.
