Model attributes (Heat Overlay)
The heat overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the heat overlay and can be modified as such.
Attribute | Unit | Description |
AVERAGED_LAST_RESULT | boolean | Whether to ignore the date-time setting for the last calculated timeframe, and show an average of the results of all preceding timeframes instead. |
DAILY_AVG_RADIATION | Wm-2 / hr | The average of amount of sun radiation per hour per square meter for this day, measured at a weather station. |
DAILY_AVG_WIND_SPEED | m/s | The daily average wind speed measured at a weather station at the height of 10 meters above ground. |
DAILY_TEMPERATURE_MAX | °C | Maximum temperature measured at a weather station. |
DAILY_TEMPERATURE_MIN | °C | Minimum temperature measured at a weather station. |
DATES | timestamp | Dates define the amount of timeframes and are used to define the day and time for calculating sun angles. |
EXCLUDE_BUILDINGS | boolean | |
EXCLUDE_WATER | boolean | |
FOLIAGE_AREAS | boolean | |
HOURLY_HUMIDITY | percentage | The relative humidity of the air at this hour, measured at a weather station. |
HOURLY_RADIATION | Wm-2 / hr | The amount of Sun radiation this hour, measured at a weather station. |
SUN_DAILY_MOTION | factor | A factor used in calculating the Atmospheric Temperature from the calculated Urban Heat Island value. |
HOURLY_TEMPERATURE | °C | The temperature at this hour, measured at a weather station. |
WIND_SPEED | m/s | The wind speed measured at a weather station at the height of 10 meters above ground. |
WIND_DIRECTION | Geo angle | The wind direction viewed from above, with 0° corresponding to north, and increasing in a clockwise fashion. |
SUN_ALTITUDE | ° | The sun angle up from the horizon. |
SUN_AZIMUTH | Geo angle | The angle along the horizon, with 0° corresponding to north, and increasing in a clockwise fashion |
- The sun altitude and azimuth are calculated automatically based on the project world location and the date.
- Some model attributes have to be based on a reference weather station.
