Feature attributes (Heat Overlay)
This article is a stub.
Construction attributes
Each construction may also have attributes which can contribute to the calculations the Heat Overlay. These attributes are stored and used on a grid cell level.
These attributes can be changed individually per construction or per construction's function. In most cases, these attributes already exist as a function value.
Icon | Attribute | Unit | Function value | Description |
BOWEN_RATIO | ratio | Bowen ratio | Describes the rate of heat transfer for a surface that has moisture as a factor. | |
FOLIAGE_CROWN_FACTOR | ratio | Foliage crown factor | The ratio between the height of tree trunks and the radius of the foliage of the tree. | |
VEGETATION_FRACTION |
Terrain attributes
Area attributes
Attribute | Unit | Description |
FOLIAGE_HEIGHT | m | The top height of foliage for a surface geometry described by an Area. |
