Attribute Actions
What are Attribute Actions?
Attribute Actions are a convenient way to be able to add a new or update an existing attribute of a building in the Tygron Platform. By adding the Attribute Action to an Action Menu, the user can directly impact speciffic seleceted buildings without the need to create elaborate upgrade functions or panels. Attribute Actions can also be stacked, multiple attributes and values can be added and/ or adjusted with one single Attribute Action, selected from an Action Menu.
Where can I find Attribute Actions in the Tygron Platform?
EditorFuture Design (Ribbon tab) → Attributes (Ribbon bar)
Attribute Actions can be found under the Future Design tab in the editor of the Tygron Platform.
How to add Attribute Actions to a project
EditorFuture Design (Ribbon tab) → Attributes (Ribbon bar) → Add Attribute Action (Dropdown menu)
How to add Attribute Actions to a project:
  1. In the editor, select the Future Design tab
  2. Select Attributes
  3. From the dropdown menu, select Add Attribute Action
  4. The new Attribute Action now appears in the Left Panel
How to add an Attribute Action to an Action Menu:
  2. Select Actions
  3. Add a new, or select an existing Action Menu on the Left Panel
  4. Select the Actions tab on the Right Panel
  5. Click on the Attribute Actions entry, and check the desired Attribute Action
  6. Now the newly added Attribute Action is available in the selected Action Menu
How to change Attribute Actions in a project
EditorFuture Design (Ribbon tab) → Attributes (Ribbon bar) → Show Attribute Actions (Dropdown menu) → Select Attribute Action to edit (Left Panel) → Adjust values of selected Attribute Action (Right Panel)
How to edit an Attribute Action or its values:
  3. Select the desired Attribute Action from the available Attribute Actions on the Left Panel
  4. On the Right Panel you can now edit the Attribute Action by changing, adding or removing attribute/ value pairs
Video
Attributen toevoegen en functies stapelen met ‘attribute actions’ (Dutch only)
Documentation
https://support.tygron.com/wiki/Attribute
https://support.tygron.com/wiki/Average_Overlay
