Model attributes (Water Overlay)
Revision as of 12:26, 14 August 2020 by Rudolf@tygron.nl (talk | contribs)
The water overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the water overlay and can be modified as such.
Icon Attribute Unit Description
CULVERT_DEM_THRESHOLD_M m The maximum distance a culvert's height can be below the terrain, for the terrain height to be adjusted to the threshold of the culvert.
GRAVITY m/s² Used constant for gravitational acceleration.
GROUND_WATER nominal value Whether and how water in the underground is simulated during the calculation.
GROUND_WATERTABLE_WITH_SURFACE boolean Whether the ground watertable result type should also include the surface water level, when the groundwater levels are close to the surface.
LIMIT_RAIN nominal value Whether and how calculations in the simulation should be limited to specific locations of the 3D world.
MAX_WATER_BOTTOM_M m + datum The maximum height for the bottoms of water terrains. Any water terrain with a bottom at a higher datum height has its bottom lowered to this value.
MAX_WATER_DEPTH_M m The maximum depth of water on a cell that is able to move horizontally. This parameter can be set to influence the wave part in the Saint-Venant equations.
MINIMAL_CULVERT_DIAMETER_M m The minimal culvert diameter in meters.
OBJECT_CORRECTION boolean Objects (culverts, pumps, weirs) can sometimes overlap each other and then one or more objects become inactive. When this happens the rasterizer automatically moves the inactive object(s) start/end point(s) by a maximum of one cell so the object(s) become active.
File:Waterwizard icon seepage fluctuation.png SEEPAGE_FLUCTUATION head (m) The additional head of higher areas outside the project causing groundwater seepage. This seepage fluctuation is added on top of the base seepage. This variation can be defined over time, similar to a weather's rainfall.
SEWER_OVERFLOW_THRESHOLD fraction (m/m) How much of a sewer's storage must be filled with water before the sewer's overflows are allowed to overflow water.
SHORELINE boolean When a Waterway polygon is not correctly positioned in relation to the DEM this can result in filling up the nearby land with water at the start of the simulation. This will result in a lower water level then is expected from the water level area value. To correct this, a "shoreline" is added at neighbouring cells. At the start of the simulation, these shoreline cells will also be filled with water up to the nearby water level to prevent the initial flush. By default this option is turned on, but can be turned off by changing the attribute to 0.
TIMEFRAMES integer The number of intermediate results recorded during the calculation. Each timeframe becomes a snapshot of data which can be viewed and analysed.
