How to edit the attribute information of an address
Revision as of 12:35, 23 November 2020 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page Edit the attribute information of an address to How to edit the attribute information of an address without leaving a redirect)
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar)
How to add an attribute:
  1. Select the building that you want to edit.
  2. Go to the right panel and press Attributes.
  3. Select building or address you want to edit.
  4. Select the intended attribute and edit as desired.
Example of adjusting the attribute information of an address
