Subsidence Overlay overview
The overlay offers the following result types:
SUBSIDENCE | m | Total | The amount that the ground has lowered as a result of subsidence, both oxidation and compaction. |
OXIDATION | m | Total | The amount that the ground has lowered as a result of peat oxidation. |
SETTLEMENT | m | Total | The amount that the ground has lowered as a result of compaction. |
HI_GROUND_WATER | m | Total | The distance between the ground surface and the highest ground water level. |
LOW_GROUND_WATER | m | Total | The distance between the ground surface and the lowest ground water level. |
Legend
The legend of the subsidence overlays is automatically calculated, based on the amount of years being calculated by the overlay. The colors will remain constant based on average subsidence per year. I.e. if the amount of years is doubled, the values in the legend, corresponding to specific colors, are doubled as well. Because the legend displays total amounts of subsidence rather than averages, the displayed range of amounts changes when the amount of calculation years changes.
The legend of the groundwater overlays is constant, and will display a color from blue through yellow to red to indicate how wet the soil is. The closer the groundwater is to the surface of the land, the bluer the overlay. In contrast to the subsidence legends, the range of values for groundwater do not change.
Subsidence legend for 30 years
Subsidence legend for 60 years
Groundwater legend
Output
The output of all result types of the overlay is in meters. The results can be exported as GeoTiff.
Timeframes
The amount of timeframes generated for the subsidence overlay are determined by Years (Subsidence Overlay) divided by Years per timeframe (Subsidence Overlay)
Subsidence output
The output of the grid of each subsidence result type is the subsidence in meters. Depending on the exact result type used, the output is the amount of subsidence as the result of one specific calculation, or the sum of all the calculations of subsidence.
The hover panel will display the following information:
- The amount of subsidence taking place over the configured amount of years.
- The current surface water level, and to what level it will have changed after the subsidence has taken place.
- The indexation policy currently configured for this water level area.
Groundwater level output
The output of the grid of each groundwater result type is the final distance from the groundwater level to the surface of the land in meters.
- The level to which the groundwater will have changed, after the subsidence has taken place.
Final water level
The overlay can also write the final surface water level to the water level area.
