Breach input area (Water Overlay)
Icon | Key | Unit | Range | Description | Default value |
BREACH_INPUT_AREA | ID of an Area | The Area item representing the influx area for the breach. | none |
- To attach a breach input area to a breach using the configuration wizard, ensure that the desired input area does not have a BREACH_HEIGHT attribute but does have a BREACH_INPUT_AREA attribute (set to -1, for example). That area is then selectable as an input area in the configuration wizard, in the step for breaches areas.
- The breach references the breach input area by filling in the ID of the breach input area for the BREACH_INPUT_AREA attribute in the breach area.
- When a Breach input area is defined, an external water body will not be created. Subsequently, the EXTERNAL_SURFACE_LEVEL, EXTERNAL_WATER_LEVEL and EXTERNAL_AREA attributes will be ignored.
