Relation (TQL)
| Clause | As a polygon | As an item | Type |
| RELATION | OWNER, CONSTRUCTOR, DEMOLISHER, PERMITTER, SENDER, RECEIVER, NETOWNER, BORDER_A, BORDER_B, BUILDING | Rather than data of the specified item, use the item which has this relation to it. | Technical name indicating a type of relation. |
Implemented Relations
| Item type | Relation Type | Description | |||||||||||||||||||||||||||||||||||||||||
| BUILDING | OWNER, CONSTRUCTOR | The Stakeholder configured as the owner of Building | - | BUILDING | DEMOLISHER | The Stakeholder configured as demolisher of Building | - | MEASURE | BUILDING | The first Building configured for this Measure | - | MEASURE | OWNER | The Stakeholder configured as the owner of this Measure | - | NET_CLUSTER | OWNER | The Stakeholder configured as the owner of this Net Cluster | - | NET_CLUSTER | NETOWNER | The Stakeholder configured as the owner of the Net Type of the first Net Load, configured as a Net Setting. | - | NET_LOAD | OWNER | The Stakeholder configured as the owner of this Net Cluster. | - | NET_LOAD | NETOWNER | The Stakeholder configured as the owner of the Net Type, configured as a Net Setting. | - | NET_LOAD | BUILDING | The Building configured for this Net Load. | - | PANEL | OWNER | The Stakeholder configured as the owner of this Panel. | - | Zone | PERMITTER | The Stakeholder configured as the permitter of this Zone. Often the Municipality by default. | - |
Areas allow any of the relations to be configured using the api events ADD_RELATION, SET_RELATION and REMOVE_RELATIONS.
