Relation (TQL)
Revision as of 07:42, 20 May 2022 by Frank@tygron.nl (talk | contribs)
Relation is a TQL Clause that can basically switch the subject of a TQL request to an other one, which is related to the original subject.
Clause | As a polygon | As an item | Type |
RELATION | N/A | Rather than requesting data from the specified item, use the item which has this relation to it. | Technical name indicating a type of relation. |
Relation Types
Relation type |
OWNER |
CONSTRUCTOR |
DEMOLISHER |
PERMITTER |
SENDER |
RECEIVER |
NETOWNER |
BORDER_A |
BORDER_B |
BUILDING |
Implemented Relations
Item type | Relation Type | Description |
BUILDING | OWNER, CONSTRUCTOR | The Stakeholder configured as the owner of Building |
BUILDING | DEMOLISHER | The Stakeholder configured as demolisher of Building |
MEASURE | BUILDING | The first Building configured for this Measure |
MEASURE | OWNER | The Stakeholder configured as the owner of this Measure |
NET_CLUSTER | OWNER | The Stakeholder configured as the owner of this Net Cluster |
NET_CLUSTER | NETOWNER | The Stakeholder configured as the owner of the Net Type of the first Net Load, configured as a Net Setting. |
NET_LOAD | OWNER | The Stakeholder configured as the owner of this Net Cluster. |
NET_LOAD | NETOWNER | The Stakeholder configured as the owner of the Net Type, configured as a Net Setting. |
NET_LOAD | BUILDING | The Building configured for this Net Load. |
PANEL | OWNER | The Stakeholder configured as the owner of this Panel. |
ZONE | PERMITTER | The Stakeholder configured as the permitter of this Zone. Often the Municipality by default. |
Area Relations
Areas allow any of the relation types to be configured using the editor area api events ADD_RELATION, SET_RELATION and REMOVE_RELATIONS.
